7 members (Southerntruck, J Lucas, 49nut, moparguy, ndkid275, Barry Martak, 1 invisible),
80
3
Mod | | | Forums66 Topics128,133 Posts1,056,398 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Get a test light & start traceing the system. See if you have curent at the toggle switch. Then turn the switch on & see if you have curent on the other term. You have a bad connection somewhere in the system. The voltage regulator does not effect this. It controls the operation & output of the generator. After you get it running get a volt/ohm meter & put it across the bat. terms or junction block. With a well charged battery, accelerate the engine & read the volt meter. It should read 14-14.5 volts. This indicates the gen. & regulator are working. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | |
Entire Thread
engine runs, then quit while idling, now will only run with starter engaged
| Kevin Richards | 12/15/2007 4:36 AM |
Re: engine runs, then quit while idling, now will only run with starter engaged
| Flxible | 12/15/2007 4:49 AM |
| atomarc | 12/15/2007 5:13 AM |
| Kevin Richards | 12/15/2007 5:30 AM |
| atomarc | 12/15/2007 6:08 AM |
| Wrenchbender Ret. | 12/15/2007 3:32 PM |
| Kevin Richards | 12/16/2007 10:33 PM |
| Wrenchbender Ret. | 12/17/2007 12:50 AM |
| westratedel | 12/18/2007 7:27 AM |
| Mechainiac_9 | 12/18/2007 11:42 PM |
| Kevin Richards | 12/23/2007 2:35 PM |
| doc41 | 12/23/2007 11:44 PM |
| Kevin Richards | 12/26/2007 3:22 PM |
| rfs56trk | 12/26/2007 6:07 PM |
| Kevin Richards | 12/27/2007 2:41 AM |
| Kevin Richards | 12/30/2007 2:39 AM | |
