0 members (),
102
3
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | There is a machined pad on the engine block ahead of the passenger's side cylinder head. Scrape the paint away and try to read the stamped numbers and letters. The letters at the end of the sequence can be run through an engine code list to identify the cubic inch displacement and year of manufacture, and sometimes the horsepower rating. The triangles on the end of the cylinder head would indicate they're the "power pack" high-compression heads used on early 283's, but those heads will bolt on to any pre-1991 small block V-8. Jerry
