Quote
Originally posted by Buddy in AK:
...Guess you will still have lube in it and it would be good for a take the trash to the dump trailer. Not sure it would be a good way to go for moving cross country?
Because the torque tube axles mount 'floppy' I would not think they are a good option for building a trailer.
On the other hand, I though about removing all the guts, include the axle shafts, and then mounting the front spindles on the ends of the axle tube to make a trailer axle. But once you've done that, I think it would have been easier to use some square tube instead.
And then someone gave me an old camp trailer, and I think I'll just use the axle from under that it build my little utility trailer....
