0 members (),
87
2
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | It gets fairly tight in that location depending on the transmission and the size of the pipes. You may wish to consider a heat shield or insulation on the pipe near the brake unit. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
Entire Thread
Under cab power brakes with bbc and headers,,, is there a temp problem?
| GTOWNBOLT | 12/08/2007 6:49 PM |
Re: Under cab power brakes with bbc and headers,,, is there a temp problem?
| HevyHauler | 12/08/2007 9:59 PM |
| rfs56trk | 12/08/2007 10:12 PM |
| BigBlockCameo | 12/08/2007 10:47 PM |
| 56 3100 | 12/14/2007 4:40 PM |
| jomichael | 12/14/2007 10:41 PM |
| BigBlockCameo | 12/22/2007 12:49 AM |
| BigBlockCameo | 12/22/2007 1:00 AM |
| 56 3100 | 12/28/2007 1:54 PM |
| BigBlockCameo | 12/29/2007 9:12 PM |
| dale937 | 12/30/2007 3:49 PM |
| wizard 49 | 12/30/2007 5:05 PM |
| BigBlockCameo | 12/30/2007 8:56 PM |
| Hot Rod Dad | 01/01/2008 6:55 AM |
| BigBlockCameo | 01/01/2008 10:07 AM | |
