| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 202 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 202 | I got my 292 engine today from the machine shop YEAH!!!!!! and it has propane pistons, balanced and a ported and polished head. It was bored .040 over. The compression is about 8.7:1 instead of the stock 8.0:1. The simtest that spins the engine with hot oil for 25 minutes without actually running it has 4 cylinders at 180 psi. And the other 2 at 170 or just above. Anyhow what would be the best carb for mpg and reasonable power? Two single is what I was going to run but its hard to find good rebuildable ones that will run together well. Should I still go that way or should I use a 4 bbl and if so, Holley or Edelbrock? Would a 390 be enough or a 450/500 would be better? I don't want to over carb like before on my 250. It had a 600. Would like some good ole' stovebolt opinions. Yeah!!! I'm a stovebolter. Just keeping things "inline". | | |
