1 members (Hotrod Lincoln),
55
3
Mod | | | Forums66 Topics128,090 Posts1,056,024 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34586 09/16/2003 2:54 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I primed part of my my 261 last weekend. I had the push rod cover off but no lifters installed. I just had to see the oil coming out of the galleries since the 261 came with solid lifters but was supposedly drilled for hydraulics. Oil came streaming out the gallery holes on the extreme left and right. I didn't see any oil coming to the head (rocker arms not installed yet) but I didn't let it go all that long. When the engine guy is done grinding the rocker arms, I'll redo the experiment. I'll be interested in what you find. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
