My 52 chevy pu has been my daily driver for the past eight years and I have never had a problem with the engine until recently. I did a compression check of the engine last night and all the cylinders checked out except the secound from the rear of the engine. It had zero compression. The engine starts fine and runs well. What could be the problem? It is a 57 model, 235.
