Well, I'm filing this one with the 200mpg carburetor and pill the ya put in the gas tank, then fill it with the garden hose myths. Sounds like one of Paul Harvey's commercials for Casite Motor Honey.
No way am I going to believe that changing to different motor oil is going to move you from a quart of oil per tank of fuel to no oil loss.
And I've been using Rotella-T in the old gal for the last 1500 miles. That's all I got to put on her this, my first summer. Oh, and by the way I'm still loosing 1qt every 100 miles or so.
No blue smoke at all or puffs at start up. But she does need Depends.
Denny Graham
Sandwich, IL
I sure hope you're talking about the link in the 1st post??
&&& If you are still loosing that amount of oil & there is no blue smoke at all or puffs at start ups then you need to put some gaskets on that mtr.
But if your not talking about the link in the 1st post I guess you're calling me I'm a lier??????
THANKS...............
I know what I experienced, I know what I did to try to fix the problem & it worked. Believe it if you want or not.
BUT that sir is not only the FACTS but the TRUTH & I have NO reason to lie about it...Joe
