If you swapped the center section of a 55-64 axle with the bolt-in center, no sweat. If you changed the ring & pinion of an integral-carrier axle, good luck! There's about a 1 in 1,000 chance of hitting all the clearances, bearing preloads, and tooth contact patterns right on the first try.
