9 members (FishinToms53, Otto Skorzeny, Gray_Ghost, Wally / Montana, TooMany2count, 1955 1 Series, baldeagle, KEVINSKI, 1 invisible),
90
0
Mod | | | Forums66 Topics128,052 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Alot will depend on what engine and computer engine manegement system you'll be using. Some only require 1, in which case only the 1 will be needed. But some (especially newer systems) will use separate sensors for both sides, or even before and after sensors (4 total) on the cat(s) to monitor the system. make sure of what the system you're using requires.
Bill Burmeister | | | |
Entire Thread
, , v8 SBC oxygen sensor
| Tim K | 11/23/2007 12:44 AM |
Re: , , v8 SBC oxygen sensor
| LONGBOX55 | 11/23/2007 12:50 AM |
| 64fleetside | 11/23/2007 3:24 AM |
| LONGBOX55 | 11/23/2007 4:06 AM |
| Tim K | 11/24/2007 2:33 AM |
| 1Bad51 | 11/24/2007 3:05 AM | |
