| | | Forums66 Topics128,031 Posts1,055,435 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#34024 01/15/2003 3:29 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Don't forget that you need a different ign switch, one with a 'start' position. You'll have to run the wire from the "start" position to the solenoid on the starter. If your truck was originally 12 volts, you should be able to swap in a 12 volt solenoid starter from a '60-'62 truck with a 235, and not have to change the flywheel. The 12 volt starters used 168 tooth ring gears, the 6 volt units used 139 tooth ring gears.
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
