If you google "bench bleeding" you'll find it has been explained many times. Bench bleeding is the only way to ensure all the air is removed from the master cylinder.
You say "I know everyone always says to bench bleed....". You reckon everyone might be wrong?
(Said with a wink. Not trying to be a smart you know what.)
