| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | Using a 24.5" wheel won't get you as much extra speed as it appears. The 22" tube-type tire and the 24.5" tubeless will have the same overall height, due to a shorter aspect ratio (height/width percentage) on the tubeless 24.5" tire. There are some very high profile tubeless tires for military use, but they're scarce and expensive. Jerry
