| | | Forums66 Topics128,021 Posts1,055,351 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Thanks. Yes it has an alternator. I had to pull one of the wires going to the coil to shut off the motor this morning when the key didn't do the job. So you seem to be onto something with you touching wires feeding the coil. I didn't touch anything other than pushing my hands up into the tight space under that dash to mount the two speed adapter which didn't work either when I was done! I'll look at the wires again in the morning to see if I screwed that up as you post makes sense. Thanks :-) | | |
