Having the 5 spd. tranny, & air brakes, tells me it's a Heavy Duty, (at least 450 series 3 ton)GMC Truck. The first 3 numbers from the engine(flat ledge, at base of distributor), will tell you the ci. displacement. Also if the carburetor, is on the passenger side of the engine, it's a Heavy Duty Line GMC.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
