10 members (TexasJim50, Thom75, Chip O, moparguy, Gdads51, Charles in CA, RaNfLaS, Otto Skorzeny, TexasFarmTruck, 1 invisible),
93
3
Mod | | | Forums66 Topics128,288 Posts1,058,548 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#33517 02/28/2002 7:53 AM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Usually the tube's full well sortta.You can bleed it at the gauge.Un hook the coil wire and run the starter crack the nut and fill the line. Once you get this really sorted the pressure should be stable Readings flux when the gauge isn't dampened
My 39 BMW fluxes all the time. Large lines and I'mm seeing the pump'stroke' but I think that's uncommon | | | |
Entire Thread
just installed a mechanical oil pressure gauge, need help...
| gmcfan | 02/28/2002 7:41 AM |
Re: just installed a mechanical oil pressure gauge, need help...
| J.H.Proffit | 02/28/2002 7:53 AM |
| gmcfan | 02/28/2002 8:09 AM |
| jack | 02/28/2002 12:15 PM |
| smitty62 | 02/28/2002 8:32 PM |
| redshiba | 02/28/2002 9:28 PM |
| Curly | 03/01/2002 6:11 AM |
| Montana Andy | 03/01/2002 7:58 AM |
| 4ontheFloor | 03/01/2002 8:46 PM |
| KingFish | 03/02/2002 3:57 AM |
| Racecarl | 03/03/2002 4:07 AM |
| bullfoot | 03/03/2002 5:21 AM | |
