Thanks guys!
It looks just like the picture in the link Kenny W provided, plus I found a site that said 3:21 gears were available for the late model 14 bolt rears. So, it appears I have a late model rear with 3:21 gears, which is good news. I won't have to swap out the pumpkin for a higher gear ratio.
I will still pull off the cover and make sure nothing looks worn. I'll count the teeth then to verify the ratio.
Thanks all for the great replies!
50-3600-Guy
