Kook, I recently had a GMC radiator rodded out & cleaned. The shop removed the funky top tank valve & soldered in a plug. I installed the radiator using a 4 lb. cap & I installed the original GM overflow condensor tank on it. No problems even here in the hottest of deserts.
