Winter is Coming
I used to have a '51 GMC 350 w/248 and radiator with the 4 lb. relief valve in the top tank. I pulled it out, got some high-temp sealer and was done. Connected the overflow to an aftermarket recovery tank. I never lost coolant after that.
