I have also read from sevral sources in years past that 10% ethanol shouldn't be a problem. It's the 85% ethanol blend that will kill the rubber parts quickly, assuming you can even adjust the timing to run on it. All I've ever read says that anyhting under 15% ethanol shouldn't cause problems.
