You Guys Rock! after about 30 seconds, I found the small hole on the block. Spring popped in right through the 40 years of grease. I found the carb leaking (leaking is not the right word, it was pouring out). Pulled the carb thinking it was a stuck float and found someone else must have tried it before as every screw was loose. The screw holes in the top were stripped, so I had to temp fix, with a couple small STOVEBOLTS of course. The old gal is running!. I even had to take it around the block.
