| | | Forums66 Topics128,269 Posts1,058,398 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I would skim the flange faces on the intake parallel. After it's done stand it on a flat surface and try to push a .002" feeler under it. Someone inexperienced will distort it worse when they clamp it on a mill and that's likely what's wrong with yours.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
