0 members (),
159
2
Mod | | | Forums66 Topics128,260 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31983 11/11/2002 4:47 AM | Joined: Nov 2000 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2000 Posts: 21 | Had my 48 Chevrolet half ton front springs rebuilt with reverse eyes. The distance from the top of the rubber bumper to the bottom of the frame rail is about 2 inches. The original lever shocks have been removed by the previous owner. Picked up the after market kit to install later AD tube shocks. The shocks are to long, less than one inch from bottoming out and the extreme angle to the front seems like it would not work very well. I am thinking of getting a shock with no dust cover and mounting then vertical with the rod end connected to the Ubolts. This would clear the rod from the pitman arm to the steering knuckle. If I install the rod end up there is not enough room between the spring pack and the steering rod. What do guys do for shocks using mono leave springs?
1948 Chevy 5 window "6" powered
