| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31914 02/13/2004 8:34 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Have you checked to see if the distributor advance weights are moving freely and the springs are there? Does the vacuum advance work? If those things are ok it's probably the carb, although you may want to check the compression, because if it is low you will have a heck of a time getting it started.
