0 members (),
79
Mod | | | Forums66 Topics128,021 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#31762 10/02/2002 5:49 PM | Joined: Jul 2000 Posts: 579 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 579 | The red dohingy in Milhouse's diagram is more diamond-shaped and called a "guide plate" in the shop manual. The spacer-object in 53chevytruck's photo goes on the back side just under the lock washer according to Fig 1 "Front Axle Assembly Cross Section" graphic on page 3-2 of the shop manual. You have to study the graphic carefully 'cause there is a "Flange Plate" on the shoe side that helps to position the wheel cylinder and add strength and in section, it looks similar to the spacer-object. | | |
