Not quite correct. To clarify, the pumpkins swap only for the 3/4 ton trucks - which have always been open driveline.
No such luck for the closed driveline, you still need to go with the expensive swap kits.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
