| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30902 12/02/2003 10:55 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The 3836848 is the good 235 head and the 3836850 is the good 261 head. They both have the same port and valve size and flow the same amount, but the 848 head increases compression ratio about 0.5 when used on a 261. The 850 261 head has some extra water passage holes that need to be added to the 235 head if it is used on a 261. Other heads don't have as good of flow capacity (none of them could be called great) and are not really desirable but do work if you need something to get you going.
