off the side of my head I say it is 45lb/feet.
Start at the middle two bolts and slowly work your way back and forth to the outer bolts/nuts.
Do them at 15lb/ft, then 30lb/ft, then final 45lb/ft.
after it has been fully warmed to operating temp and has been driven, recheck them at 45lb/ft. cool
There is enough good in the worst of us and enough bad in the best of us that it does not behoove any of us to criticize the rest of us.
Be yourself. If you are ever lost, It will be much easier to find yourself if you know who you are!
