| | | Forums66 Topics128,043 Posts1,055,524 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30711 11/01/2003 5:33 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | BrianT,
I have always disconnected the vacuum advance line and plugged it; however, the 1954 and 1960 shop and owners manuals do not mention disconnecting the vacuum line.
Use a timing light for setting timing. Adjust the points; then adjust the carburetor (with a vacuum guage). Then, attach the timing light to the #1 spark plug wire and rotate the distributor until the ball on the flywheel lines up with the needle in the front side of the bell housing.
Tim | | |
