| | | Forums66 Topics128,095 Posts1,056,067 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30295 08/05/2002 7:44 AM | Joined: Jul 2002 Posts: 18 Junior Member | | Junior Member Joined: Jul 2002 Posts: 18 | the 216 in my 49 3600 started and ran well but was knocking so with engine inframe i adjusted the rod bearings, and #6 was +.002, #5 crankshaft journal and rod babbit is 'spun' and looks like a moonscape.i removed shims and also sanded rod cap for a closer fit. #1-4 are shiny and required no adjustment. I put the oil pan back on and am deciding what to do next. what do you recommend. I would like to be able to drive the truck in and out of the barn and to the gas staion for while i do some other mechanical/cosmetic restoration. is 'grey paint' in the bottom of the oil pan crud all thats left of bearings? I don't have any precision measurement equipment to tell what else is worn. I could 1-spend $2000 on a complete rebuild? I'm under the impression this would last 30K miles? 2-have the crankshaft repaired? is this "good as new" 3-buy a new rod? buy a used rod? 4-have the rod bearing repaired? 5-drive it until it squeals and/or destroys the engine? to keep it original, a 235 swap is out
" the first rule of the intelligent tinkerer is to save all the parts" aldo leopold
