| | | Forums66 Topics128,031 Posts1,055,434 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30116 02/04/2005 9:37 PM | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | lutrexen!
Check your battery cables. Make sure they are 'big' ones if you're running 6 volts. Connect your ground to the starter mounting bolt and make sure all connections are clean. Had the same problem and after making up new cables the problem was solved. Others on here have said the same thing.
George | | |
