| | | Forums66 Topics128,110 Posts1,056,242 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#30111 11/17/2003 1:29 AM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | OK, OK. I'm babbling in this thread but I've got it figured out. I mapped out the events in a 4-stroke, 6-cylinder engine with firing order 153624. Sure would have been easier for a 4-stroke, 4-cylinder. I was hoping that someone would know this off the top of their head. I'm focusing on pushrod positions because the engine is being reassembled.
When #1 is at TDC, only #2 exhaust and #3 intake valves are fully open (pushrods up). #4 is in a power stroke, #5 is in compression and #6 is between its exhaust and intake strokes.
If you are 180 deg. out with the flywheel ball also at the pointer, only #4 intake and #5 exhaust valves would be fully open (pushrods up). #1 would be between its exhaust and intake strokes and both pushrods would be down.
Confirmation, anyone? 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
