| | | Forums66 Topics128,037 Posts1,055,580 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29903 06/03/2004 4:47 PM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | I think your plan to add MMO to the cylinders is a good idea.
I'd drive it for a bit after clearing out the MMO, then do a compression test - both dry, and then with oil added to the cylinder.
Did you add the transmission fluid BEFORE the smoking started? I believe that too much detergent in the oil can clean an older motor too well and cause smoking and oil consumption to increase. | | |
