I fell into this one - never expected it!! I bought rubber clutch and brake pedal covers and a new accelerator pedal from Chevy Duty. After the easy job of putting on the clutch & brake pedal covers I went after the new accelerator pedal. While trying to get the linkage to stop binding, I took the whole thing off and rebent the throttle rod (the one connected to the accelerator pedal). After several trial & error installations and a little help from the other half, I realized that the throttle never did open more than halfway!! So after a few more tweaks I got it set correctly. After a quick spin down the road & back, I've got a sneaky hunch my 'Thriftmaster' won't be so thrifty anymore!!
If you think you can or if you think you can't, either way you're right.
