7 members (Gdads51, Otto Skorzeny, Goach2, Jay R, 1955 1 Series, Oswald, Wayne67vert),
104
3
Mod | | | Forums66 Topics128,268 Posts1,058,391 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29458 01/12/2005 2:34 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Are you sure that the Drum is free of the Axle? If not take a 3 or 5 lbs malet and hammer outter edge of the face(flat part) of the drum. I usually start at 12 o'clock then 6,3,9 and keep moving around the drum. Once the drum is free from the axle and if it still won't come off try this. Look at the backside of the Backing Plate. Look for the anchor pins that hold the shoes to the backing plate (should be at 6 and 9 o' clock positions). If possible grab hold of the pins (from the back side) pull them toward the opposite wheel and the cut them with a small die grinder or side cutters. This should allow you to pull the drum and shoes off at the same time.
Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
