| | | Forums66 Topics128,035 Posts1,055,566 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#29323 04/23/2005 8:49 AM | Joined: Apr 2005 Posts: 36 New Guy | | New Guy Joined: Apr 2005 Posts: 36 | IT JUST DEPENDS ON HOW DeeP YOUR NEW FAN SITS. ALOT OF THE TIME YOU CAN JUST REMOVE THE FANS AND YOU WILL BE GOOD. i RECOMEND REPLACING THE PULLEY IF YOU CARE ABOUT PREFORMANCE. THAT WAY YOU TAKE OFF AS MUCH WEIGHT AS POSSIBLE AND that way it actually makes it worth the time and effert to replace the fan. you engines not spinning something useless
DustyG.
1952 Chevy 1.5 ton 1949 Gmc 2 ton flatbed Dump
