| | | Forums66 Topics128,164 Posts1,056,982 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28887 12/01/2004 1:45 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I did this on a '41 1/2-ton 30+ years ago.
What I remember was swapping the drums, hubs and backing plates.
I think I used the inner bearing from the truck hubs and the outer bearing from the car hubs.
Those old car brakes are going to be tough enough to find that I'd investigate using more recent brake stuff instead.
When I converted the front of my '55 1st to disk brakes I used '73 Chevelle disks. Outer bearing was the one that came with the disks and the inner bearing was provided by the vender I bought the kit from (along with a collar that made it fit the spindle). The spindle nuts from the Chevelle fit my spindles.
I'd bet you could use a similar approach to adapt drum brakes off a 60s GM car with drum brakes.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
