| | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#28129 07/15/2004 7:37 PM | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | From Carter's ads in the early 50's:
"The ABC's of carburetion: Always Buy Carter!"
The Carter carbs are better, but there's nothing wrong with your Rochester. I've had some success draw-filing the tops of carburetors where the main body and the top meet, but it has to be done carefully. During a rebuild, take a big, flat file, and carefully dress the mating surfaces unti they fit flush and compress the gasket evenly at all points. Be sure and do a good cleanup to keep the file shavings from getting into passageways and clogging them. I really don't like sealers anywhere around a carburetor, or intake mainfold. There's just too much risk of getting it pulled into a vacuum passageway and ending up sealing off the wrong place! Jerry
