Probably get an oil pressure guage from the parts place and hook it up temporarly (or mount it under the dash permently). Unless you want to loosen the sending unit real loose and put a bucket under and crank engine-turn off before you pump your pan dry. Maybe someone else has a way.
Truck Tinker from Talking Rock
