The speedometer in the dash is long gone, when I took it out the screeching stopped. The odometer works on the same cable and was working just fine with no noise until I switched transmissions. Since I tried switching the external speedometer gear on the trani I assume it is the mainshaft gear? simple or hard to replace?
