| | | Forums66 Topics128,036 Posts1,055,461 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27700 04/29/2003 11:11 PM | Joined: Jun 2002 Posts: 29 Junior Member | | Junior Member Joined: Jun 2002 Posts: 29 | My speedometer never worked, after I was done rebuilding my 58'1/2 ton the speedometer just screeched and bounced around wildly so I took the speedometer out. The ODOMETER worked fine. Because of a bad syncro in the original transmission I found a replacement from a 59. After the switch my odometer never worked. The cable hooks up the same. I even switched the speedometer gear on the side of the transmission. They looked identical but it didn't help. I assume the gear on the mainshaft of the transmission is out. any other ideas? should I rebuild the original transmission with the bad synchro or the working transmission which doesn,t turn my odometer(speedo cable)? | | |
