| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27272 02/04/2003 6:23 AM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | I guess if you can't find a Chevy Rearend then buy the **** Rearend. You have to cut the old hardware off the rearend and weld on new spring perches "if it's a Chevy or **** Rearend". The only problem with a **** is the different lug pattern!!! Your looking at 2 different lug patterns and carrying two spares or having the bolt pattern re-drilled to the Chevy pattern out back so they'll all match. You can pick up the new spring perches at a local trailer supply store or online at http://www.summitracing.com "that's where I buy mine".
Joe
