| | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#27135 06/10/2004 7:45 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Most any of the vendors should have the lines and the gauge. You can also try locally for the lines, but you need to take them in to the parts store to see if they have anything that will work. Another source is to get some made at a hydraulic hose shop. Usually if one needs replaced I change them both.
Fred 52 3600 69 C-10
