Before I get too gung-ho into the "235" that I put in my truck, I thought that I should identify the engine exactly. Supposedly it is a 235 from a 57 chev car. The stamped casting number does not seem to match anything that I have found. 233692. Any suggestions as to how I can verify the engine year and displacement? I am assuming that I can pull the head and measure bore and stroke for the displacement, though I would rather not.
Thanks
David
