| | | Forums66 Topics128,021 Posts1,055,372 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26856 01/17/2002 3:14 AM | Joined: Dec 2000 Posts: 64 Member | | Member Joined: Dec 2000 Posts: 64 | You may want to check to make sure the plug wires are on the correct cylinder. If you have no.3&4 changed around it will backfire through the carb. also make sure the distributor cap doesn't have a crack from one cylinder to another.
kdot em3
