| | | Forums66 Topics128,041 Posts1,055,490 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26738 04/30/2004 10:23 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If you replaced the cam gear with fiber, what you are hearing now will probably go away once the fiber gear gets enough wear to break in. I don't see a need to replace the steel crank gear unless it had some burrs on it. The fiber gears aren't as noisy as aluminum, but the don't last near as long either.
You are putting a big load on the 250, but with 5.13 gears you should be okay as long as you don't try to run too fast. I would keep the rpm under 3,000 on the highway, don't know what that figures to without knowing the tire diameter. A 292 would be nice if you can find one. They're not an easy score around here, the farmers use them for running irrigation pumps.
Fred 52 3600 69 C-10
