| | | Forums66 Topics128,030 Posts1,055,423 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#26327 08/16/2004 5:39 PM | Joined: Feb 2001 Posts: 198 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 198 | Most parts shops have a one-way bleeder set-up, usually for only a few dollars. (must be cheap 'cause I bought one!) It's simply a hose with a one way valve on the end and, sometimes, a screwtop with a magnet to attach to the backing plate. You supply the jar. Suck out the old fluid from the m/c.. A turkey baster works, but can be messy. refill with new. You can pop a bleeder and pump the brakes until clean fluid comes through. Will take a while. and DON'T FORGET to check the m/c level every once in a while.
Attitude - The difference between an adventure and an ordeal! Deja Moo - The feeling you've heard this bull**** before! '63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red' '69 or'70 or ? Mantaray DuneBuggy
