All good points so far,,,
I re-read your first post and saw this which got the tw gears grinding in my head ,,, not much else in there eek .....
_
Originalquote from bluebird,,,
Quote
I resurfaced the flywheel and reattached it to proper specs. I then replaced the old clutch plate, pressure plate, throw out bearing and input shaft bearing.
Are these parts new?
OR are they the old ones?
(It says replaced the old pieces) :confused:
If these parts are used/old, there may be some problem with the throw-out bearing,,,
Just curious
There is enough good in the worst of us and enough bad in the best of us that it does not behoove any of us to criticize the rest of us.
Be yourself. If you are ever lost, It will be much easier to find yourself if you know who you are!
