Jeff you have a set of plates that falls under the exemption part of YOM (YEAR OF MANUFACTURE) You have a set of 63 plates that are still legally registered, once they have been turned in they will no longer be exempt and cannot be used again. What this will do is open up the numbers and letters for someone else that has YOM plates that they could not get registered ie: a set of 47 plates with the same number.
George 1948 CE, 1949 CE, 1950 Suburban, (2) 1951 Suburban, unknown (AD) CE, 1948 GMC Suburban
