Hi Welch 63, Welcome to the Stovebolt Page.
For starters, read the number from the shelf on the engine block to the left of the distributor. Most likely it will start with 228. If so, you have a 228 GMC engine.
You don't mention whether you truck is a 1/2 or 3/4 ton truck. Does it have any markings on the hood ? A 100 emblem would be the mark of a 1/2, a 150 denotes 3/4 ton.. If you are thinking about changing the rear gears to a higher ratio, your choices depend on whether it is a 1/2 or a 3/4 ton vehicle.
You said it has a stick on the floor , it is probably a 4 speed transmission..
Give us a little more information and I am sure a few guys will jump in with some ideas..
